Hi, I have a n image in bmp and jpeg format that when I import looks ok, but when UI move it, then image flips, for example the positive parts become negative and vice versa
No, it’s cool. In the GFUI, the colored parts of the image are what will be engraved. The dark is really invisible / do not engrave section. The dark is the crumb tray you see so it just looks like the image is inverted. In the example below, the purple color is what the GF will engrave
Keep in mind that this is a subtractive process. The shaded sections are where material is being removed.
Thanks for the answer, @gmckayca and @Tom_A, that’s correct! I’m going to close this thread. If you run into any other trouble, please start a new topic, or email us at support@glowforge.com. We’re here to help!
