Is there a way to add a design from the Glowforge catalog on the same cutting sheet. I downloaded some items and want to cut them at the same time, how can I export them from the dashboard into the uploaded design? ie. two pairs of coasters different purchased dates same cutting at the same time. Is that possible?
There’s no way to copy a Catalog file out of the gui. Your best bet only option is to simply run separate prints.
Welcome to the Community! I took the liberty of moving your post to “Everything Else.”
You can cut the first, leave it in the machine, open and cut the 2nd, and then pull everything out - that way you know it’ll all fit together on one sheet
