Hello,
I’m in search of thin leather. Does anyone know of any sites that carry?
Hello,
If you search for leather suppliers on the forum you’ll find many, but “thin” isn’t a great descriptor. Different types will have significantly different strengths - what are you looking for it to do? If you need it to carry weight vs sewing it on as a tag will get you different answers.
My personal go-to is always Tandy Leather. They have pretty solid descriptions that should get you started.
Thank you.
I will be eventually be sewing. For now bending and gluing. The thicker doesn’t bend like I want
Look here - you’re likely looking for 1-3oz stuff, but thicker can still be soft.
https://tandyleather.com/collections/leather/tannage_veg-tan?
For example the medium leather is quite stiff, but this milled veg-tan is the same thickness (3-4oz), and completely malleable. It’s my favorite product
This may also help:
This is what I needed. Thanks
Here is another to look at.
Has anyone found any leather that’s under 2 oz?
If you want it that thin you may not want leather…
Pigskin suede splits are typically 1-1.5oz but they’re VERY soft and meant for linings. If you want 2oz top grain you may have to either split it yourself or have a leather shop do it for you.
I’m looking for a replacement for the glowforge 1/48 leather
In leather terms, an ounce is 1/64". Here is an ounce to thickness chart for leather.
Ounce Thickness | Inch Thickness | Millimeter Thickness |
2 – 3 oz | 1/32 – 3/64 in | .8 – 1.2 mm |
3 – 4 oz | 3/64 – 1/16 | 1.2 – 1.6 mm |
4 – 5 oz | 1/16 – 5/64 in | 1.6 – 2.0 mm |
5 – 6 oz | 5/64 – 3/32 in | 2.0 – 2.4 mm |
6 – 7 oz | 3/32 – 7/64 in | 2.4 – 2.8 mm |
7 – 8 oz | 7/64 – 1/8 in | 2.8 – 3.2 mm |
8 – 9 oz | 1/8 – 9/64 in | 3.2 – 3.6 mm |
9 – 10 oz | 9/64 – 5/32 in | 3.6 – 4.0 mm |
10 – 11 oz | 5/32 – 11/64 in | 4.0 – 4.4 mm |
