Inkscape gang check it.
Awesome! Thanks!
Thanks for the heads up.
Thanks for the heads up! I have at last integrated the last update so I may be a while before learning the next one. There are a few that I passed off to Gimp having never managed to control the Inkscape sufficiently.
Does it work better with Mac OS? It was terrible with Mac! Not even useable because of the extreme lag. I hated it and had to start using Affinity Designer instead.
Dunno, Iām a pc guy.
Iām hoping it does work better with Mac because, other than the extreme lag, I really liked it.
My impression is that there was a lot of attention to the Mac OS as that would be the greater source of complaints.
The release notes donāt sound promising. Youād think if theyād made any significant performance improvements theyād at least mention them, but the macOS-specific part only mentions a new icon, fixed Visio importing, and the removal(!) of Postscript support (they ran into legal problems with bundling ghostscript). Hopefully they get the legal issues of Ghostscript figured out for future versions.
macOS-specific Changes
- New Inkscape icon (Bug #2072)
- Visio files can be imported (Bug #2094)
- Breaking change: We can no longer bundle Ghostscript, effectively removing out of the box support for EPS and PS (MR #2608).
Learn how to work around this restriction .
Thanks for the heads-up - off to download it now.
1.0 has been great
Thank You
i have slowly been figuring inscape out since I got my forge. will check this out.
The āExport PNG Imageā dialog now exports PNGs with one click instead of two.
I may weep tears of joy.
for a year, i thought it was broken. then I figured out the 2nd click. someone was not fully awake when they designed that.
PANIC
Iāve been using 1.1 for the last couple of days, and noted improvements, but this morning as soon as I try to rename a file that I want to keep in its altered version, and hit the āsave asā button, the whole program closes !!!
Iāve tried several times, and also restarted the program, but to no avail.
In the middle of rush job, and somewhat b*****ed.
Anyone else with this problem - Iām running it in Ubuntu 20.04 currently as my OS .
John
EDIT
Just been on the Inkscape Community, and was advised to re-install, as it was a known bug that was sorted with a new build a few hours ago !
Not happy with 1.1 on a Mac. Crashes, etc. Going back to 1.0.2
On my end:
ESCAPE no longer exits the current toolā¦you have to press āSā. Moderately frustrating.
Pressing the DELETE key on the keyboard doesnāt work to delete an object.
Had my problem solved by a new build today. Re-installed and mine is now good to go.
Iām going to let the bugs work themself out before the upgradeā¦ This is not a situation where I want to be a guinea pig for a mass release.
