Thanks,
I think that it will take a practicing with each of these to cement them in my brain. Every project is a new opportunity for failure… I think the failures followed by success when you figure it out are the most solid learning experiences.
Thanks,
That is a crucial point to make. When I was first doing these booleans, I couldn’t figure out what was the deal, why sometimes it worked and others not for what I wanted to do. I’d end up trying all the functions to eventually get the right one. Then I discovered that z-order was a factor.
Great to have your understanding on the forum.
I know z-order is a factor, but I can still have problems with Difference. Eventually it all gets done.
When You want to pick a shape inside a group, rather than ungroup them you can Ctl-Click if it the first that you want or Shift-Ctl-Click to add others. I keep all the sub windows arranged on a second screen so I can both see what is happening and just reach to it.
An important such window is the object list that will show the z-order even across groups and let you change that.
The boolean thing that always got me early on was when I would have one or more paths in a group, or I would forget to change a rectangle to a path first. The boolean just silently(ish) fails, while it does say “one of these objects is not a path” the message is really hard to spot.
It still catches me sometimes, but I’ve learned to quickly adjust and smack my forehead now.
This topic was automatically closed after 32 days. New replies are no longer allowed.
