Have a dice that I’d like to engrave the pips and outline but when I load in into the ui it wants to engrave the total square
This is the file I’m working with
Thanks
Thanks
Turn the fill off on the outer shape. Then reupload it.
Orrrr… you can just manually make that a cut/score. The engrave is just the default when you send it a filled vector shape. You can override it in the ui.
