Hi, I am thinking that a nice feature that could be added to the GFUI would be the option to add a timed delay layer between cuts, engraves, scores, etc.
In addition a time delay for any single layer based on the ips or resolution. If you could say rest every .25 inch or something to that effect.
The reason I am saying this is that I have seen a lot of PG wood warping under the extreme heat generated by just an engrave/cut process. This could solve that issue without needing user intervention.
Maybe there are other solutions out there. Thoughts?
