I have read the other posts but I am not sure how far out or how it should look on the interlock pin to make sure it is properly situated. I see the round black circular plug with what looks like a staple sticking out of it. I can see all sides of the pin. I am not sure if it should be flush to the black plug or sticking out a bit.
Thank you. I will try that now. When I turn on the machine it will only stay on a few seconds and that is only if I unplug the power cord from the unit, plug it back up then turn it on.
Thank you. I see it is inserted correctly but that is not the issue any more as the machine has completely died and will not come on at all. I am still waiting to hear from tech support.
On my first pro the on off switch was funny . You had to turn it on real slow you would hear a click then a second one the it would power up . Some times you would cut it on two or three times cut it off wait about 30 seconds then it would cut on
Hello @iyomi_fashions I’m so sorry your receiving an Interlock Open message. I noticed that you sent us a previous forum post. I’m going to go ahead and close this post and reply to you there.
