Hi everyone, I was using my Glowforge last night and it didn’t cut through the material. I turned the machine off as usual and thought, I’ll rerun the cuts in the morning. I woke up and turned the machine on and it cut off after 20 minutes of me changing the settings to cut only since the engravings worked.
To my surprise, the machine would not come on at all anymore after checking the plug, turning it on/off, switching the plug out and testing the outlet.
I then went to my computer to see what the status was and it said “interlock system open”. I googled what this meant and took the pin out to reset it.
Do you guys have any other suggestions? My baby shower is in 4 days and I can’t do any of my decor. I’m so sad. Please help if you can. Thank you.
