I’m so surprised that a forum search did not yield a definitive answer. I would like to make broach pins and earrings. Is E6000 the best glue for wood to pin blank?
If I get brave enough for acrylic, what is the best glue to adhere that to a pin blanks?
I hope I get enough hours so I am confidently make good quality jewelry on my “baby”
For that application I would be tempted to use that UV cured resin, like Bondic for example. Unlimited work time, and cures right now.
For acrylic, I would recommend roughing the surface a bit to give any adhesive some “Tooth”.
I’ve had good success using a thick CA, but you do want to sand the surfaces with a coarse sandpaper to give them some tooth.
I’ve also used E6000 on a lot of projects, and it should do fine as well.
(I just don’t care for it as much cause it tends to dry out in the tube. And I wind up stringing it all over the place. If you’re non-klutz, it should be okay.)
