Kind of like a credit card?
I’m looking to make something with a quote on it, that would fit in a wallet (credit card sized). Any suggestions on a good material that’s not too thick?
Thanks!
Aluminum business card or wooden business card like those from https://www.cardsofwood.com/
Seconded on aluminum cards.
The ring lord is a good source:
http://theringlord.com/cart/
As is chewbarka or amazon.
Heavy card stock is an option–there are lots of versions that have a core and then outer colors (and different finishes–I have some metallic with black core, then there are the foil-finish versions…). The etching can create a great contrast with exposing the core for contrast to the top color, and cutting is easy–I do some business cards this way… ( I got mine from www.cardstock-warehouse.com).
You could even engrave two card-sized pieces of wood veneer and stick them together back to back.
I even found a wood veneer that is aleady paper backed–bit thinner than heavy card stock, but still works nicely for business cards, too!
