Using hardeners is a good point to make. Bookmarking for further investigation.
I have used this stuff on rotten wood and plain old paper.
http://www.jamestowndistributors.com/userportal/show_product.do?pid=2093&familyName=Boatlife+GIT-Rot&history=&engine=adwords!6456&keyword=git+rot&match_type=
It is amazing, but also expensive. I know there are cheaper one part products (minwax makes one) but I have never tried them.
Iâve used the one-part hardeners, and they sorta work. But they have to be really thin to soak in, so any seriously soft/rotten wood (like the bottoms of our doorframes will soak up pints of the stuff. Superglue probably fine for this application.
Looking at
[this stuff] https://www.lowes.com/pd/47-75-in-x-7-98-ft-Smooth-Brown-Hardboard-Wall-Panel/3014304)
Says formaldehyde free.
I used the Loweâs hardboard on a couple of laser-cutter projects at TechShop (RIP!). Itâs super-cheap, making it terrific drafting material. The surface is really smooth, and the mottled appearance has some appeal, so it might even be suitable for certain finished applications.
The downsides:
â The back of the panel is rough, about like burlap. After all, this stuff is meant to be glued to walls, and the roughness helps the glue grip. (If a product description says âsmooth on both sidesâ, DONâT BELIEVE IT! Or, at least, donât expect both sides to be finished-quality smooth.) I tried making a few double-sided things by gluing pieces back-to-back, but the roughness made for a terribly-unsubtle middle âseamâ. Sanding mightâve helped (that wouldâve been more trouble than my experiment was worth), but Iâm not sure how well hardboard holds up to that.
â The color is pretty dark, which makes engraved elements a bit hard to see. (Iâll note thatâs thereâs also white hardboard.)
â You need someone to cut those 4âx8â panels into manageable size. My Loweâs charges to do more than about two cuts; moreover, their giant panel cutter is hardly a precision instrument, so the end results tend to be far from uniform or square. (You can buy small-size hardboard panels at art stores âpainters use them as canvasesâ but the price goes up.)
I use them for quick knock together stuff - itâs about $8 for a 4x8 sheet at my Home Depot and they have the same 2 cuts for free but if itâs not busy theyâll rip it down further and they donât charge me for it. Depending on the car I have with me I usually get it down to 2x2 square and then break it down smaller at home. Iâve used it for street art stencils in longer panels using the pass through. Itâs easy to cut and the shiny side is easy clean up (relatively speaking) for paint overspray.
