Laser isn't firing up?
Of course, while trying to get something done for a work event, the laser has decided to not “turn on”. I have uploaded a file and gone through the process all the way to “print” and the machine acts like normal and then no laser. Thoughts?
Thanks!
Check to make sure the power setting for the cut or engrave is correct and the image is all on the cuttable / engravable area of the bed
Yup. Using proof grade materials.
Ok, the same thing happened to me once using PG materials, and I found the laser wasn’t firing because the power level was set all the way to the left
Thanks for reaching out.
