laser not cutting graphic in the same place on material messing up my cut and engraving
You’ll need to post the details of what you were trying to do, your laser settings, and pictures before we can help you.
Are you using the set focus tool prior to placing your graphic? When using the set focus tool, are you certain the red beam is landing on the material where you intend to place your graphic? Have you moved the printhead with the machine turned on?
THIS is for dklgood what happens when move the print head when the machine is turned on. I have noon this
If you move the printhead with the machine turned on, the software loses track of the printhead’s location. The fix is easy. Simply turn the machine off and then back on. Once it has completed its focus and homing routine, everything is back in sync.
