You should work thru the steps detailed in the troubleshooting guide. Click on Support, Troubleshooting, Cut Didn’t Go Through Material
It takes up to about one business day for them to respond, either here or by email. Both open support tickets, so now you have two - they will likely close this discussion and continue to work with you by email.
Indeed - I walked through the steps in the troubleshooting guide. In the crumb tray in dimples, clean as a whistle, should be as it is only a couple hours old. I re-wiped lens and checked everything.
Looking forward to hearing back from someone either hear or in email. Again, great service from GF just have to wait it out.
I don’t have answers, just commiseration: I have a new GF (arrived May 11) and I’m having the same problem. It worked fine on a few projects but now even the GoGM won’t cut out. I’m really having a hard time with the 24 hour (or more) response time in between emails, too.
Just guessing from the width of the outline cut, I would check that the lens is in correctly. “Cup goes up”. When the lens is reversed, the focal point (the beam waist) is off so it cuts a thicker line. the beam is convergent to the waist (the focal point) and then diverges below that point.
There’s definitely something wrong with the cut that looks like a focus issue - the holes down the left side have scored rings around them - similar to the slot cutout. You can’t even discern those on your print.
That cut line looks awfully broad, just eliminating any possibility. As @eflyguy pointed out, that’s a telling symptom. Support needs to look at your logs. It will expedite the process if you could give the date, time, and time zone you are in to locate the pertinent logs.
Did you also inspect the mirror? If you swapped entire print heads, I would be suspect of the lens on the left side of the glowforge (not on the printhead)… if it had something on it, the laser would be diffuse going from the CO2 tube to the print head. But if all you replaced was the bottom lens, look at the mirror on the top of the printhead. I had a dirty mirror, and it made for trouble. Although, I sometimes get it not cutting through proofgrade on mine
, and just slowdown the cuts by 10 or 20… instead of 155, might try 145 or 135.
But since it is brand new, get it working right
My second machine had a similar issue as yours. I also swapped the entire laser heads to see if that would fix it, but it did not. I was getting strange engraving patterns outside of the cuts being wide and not going through. In my case I was issued a replacement, so hopefully they’re able to take care of you once again.
I’m so sorry to hear that you’ve hit this snag. I’ve extracted the log files from your Glowforge to review your most recent prints, and compare it with the details you’ve provided.
Unfortunately, it looks like your unit is experiencing an issue that we can’t resolve remotely. I want you to have a reliable unit, so I’m recommending we replace this one.
Your Glowforge’s Printer Head is calibrated inside of the factory to your unit. Would it be possible to move the Printer Head to ensure that it is the original one with the new unit you’ve received?
I’ll be in touch via email to sort out the details. I’m so sorry about the bad news.
