Laser not cutting through on the right side
Hi, So whenever I cut anything towards the right side of the glowforge it doesn’t cut deep enough to go through the material, is there any reason or a easy fix anyone knows? Any help or suggestions on what to do? Has this happened to anyone else? I contacted support but idk how long will it take for any resolution and I have orders I can’t fulfill :weary:
It engraves perfect but when it is going to cut it doesn’t go through the board ( only in the right side ).
I would really appreciate your help!
Thanks in advance!
Uploading: 15ACE59B-109B-40DF-ACB8-198735A80949.jpeg…
Processing: E97192AD-91EE-486D-B2CB-1E0A38FAF90B.jpeg…
Uploading: 3D008F74-E22F-4B6B-BD34-9469C9ACB0EC.jpeg…
Processing: F189D245-4AAF-40F1-AF89-F0607EAB1AF7.jpeg…
Uploading: 508EE14E-91EB-49A5-818B-6EEE0E3FF7A6.jpeg…
If the optics are clean then it generally means the mirror inside the left side of the gantry is misaligned. It is not user-serviceable, the machine would have to be replaced.
How old is it? This is not uncommon for new machines that were abused in-transit.
If it was working fine and now not, it’s more likely dirty optics. The mirror issue would almost always show up from new.
Hi there, your uploads messed up,
I think you have your laser lens flipped upside down (ring goes IN)
see if that fixes the issues
Jonathan
Hey what does this mean ring in ? Like the lense u pop out with the tool. The arrow has to be facing up ?
the ring (cup) part of the lens is pointed toward the laser head, when inserted.
Jonathan
