My glowforge stopped firing. I’ve cleaned everything and checked all of the connections. I set the score to 300/30 and the cut to 150/full and it does nothing. The head moves as if it thinks it’s doing the job, but nothing scores or cuts.
Have you tried it on the gift of good measure to prove the machine is or is not at fault?
You mean try to cut one? No I didn’t try that. I will.
Just tried it, nothing is happening for that either. I put in proofgrade material also.
If you’ve followed the support troubleshooting steps, then it’s either a failed laser tube or power supply. Either way, the machine would need to be replaced.
