I have a new machine and the scoring on acrylic seems to be pulsating or changing in intensity and width. I have cleaned the cameras repeatedly, i have tried numerous on/off, plugging and unplugging, cleaned all the lenses numerous times and the scoring keeps coming out spotty at best. A straight line seems to blob and thin and very weak in intensity in some spots and strong in others. Any advice?
But it does. You can see from the photo it does. I’m just posting here to get Glowforge to respond about the faulty power supply and the instructions to send it back for a new unit.
Does that acrylic still have the protective plastic on it? If so, remove it before scoring. Second, that is a very fast/light score setting, try using the Glowforge acrylic default Score settings.
Hence the issue of my scoring… Not sure what your intent is with your comparison but I am getting a hostile vibe from it so I will conclude our discussion.
On the backside only. I will try the default glowforge setting, although my two other GF’s operate on these settings just fine which indicates an issue.
It might also indicate a need to clean the lens and windows, so that would be the next thing to check if you want to run at fast/low power speeds. I think the machines are individually tuned, and that one might not be tuned to quite the same settings that the other ones are. There was a recent memo from Rita about a tuning issue on a few of the machines that will be fixed with a roll out in a few days.
The default glowforge scoring didn’t have an issue. Good suggestion. It might be the tuning issue then meaning I’ll need to increase the power of it until the glowforge tuning patch.
