So I was trying to engrave today and one particular area on 2 different designs showed nothing. Over those areas the laser head moves as if it is engraving but nothing appears. The rest of the job goes fine. And the area was in a different location on each job.
What’s more strange is that if I restarted and told it to score instead of engrave it would work just fine. All other areas of the design came out just fine.
I restarted the app and the glowforge. It didn’t help.
What you are describing really points to overlapping spaces. If you post your design someone will probably be able to help.
Otherwise, check that the colors are all the same in all the letters.
Ben you were indeed right! Somehow there were 2 instances of the text sitting on top of each other. That is strange because, like I said, it worked fine earlier in the day. I guess I somehow duplicated it.
I removed the duplicate and it worked like a charm.
I was thinking that maybe the color of the letters might be messing with the power settings. I have seen things like that with some images I have worked with.
