Hey guys!
I’ve been making some LED lamps, but I don’t always like how mine look. It seems like a lot of them block out too much light for the lamp to look as good as I would like it to.
Does anyone have any tips on settings they use for the engraving on the acrylic? Currently, I’m doing focus height 5.5, 265 lines per cm and at a slower speed of 790.
Thanks!
-Shay
evansd2
December 15, 2019, 2:37am
If you search for “acrylic engrave settings” I bet you’ll get some answers without everyone repeating themselves.
There was a really good thread about this recently with a spiderman. Let’s see.
Yeah here we go, read this whole thread, lots of good tips.
[IMG_0002] [IMG_0003] [IMG_0004] My first attempt to make an LED Acrylic lit on GF using proof grade medium clear acrylic sheet.I followed some of the suggestions in the community posts and used the Amazon referred led circular bases.
Issue # Made a flat base and it does touch the LED base , but does not lit clearly all the way up.The Image I made is about 6 inches.Engraved using SD graphic setting and the outcome of the engrave is good.Can any suggest what I could be missing ? If I flip or twi…
Here’s that search, because I’m full service:
https://community.glowforge.com/search?q=acrylic%20engrave%20settings
This will probably enlighten you:
https://community.glowforge.com/search?q=edge%20lit%20engrave%20settings
Get it? Enlighten? Aw come on, where are you going!? I’ll be here all week, ladies and gentlemen.
system
Closed
January 16, 2020, 4:40am
