Is there a setting to help see if a line is level with another line?
Have you tried the position tool?
There is nothing that will tell you if two lines are parallel in the Glowforge app.
You could actually figure it out by knowing the dimensions of the lines, you just calculate the angles with some basic trig
If you are working in the glowforge interface, copy and pasting would produce a line that is parallel.
ctrl C / ctrl V, in windows, otherwise cmd,
