Little Help
Once you start a print, can you either back out to the dashboard or open a new window so that you can start working on creating your next design/project without crashing the print already in process???
Yeah you’re fine.
Once the job starts the Glowforge is independent of the ui or the internet.
I usually just open another tab on my browser. That way I can check back on the project I’m printing to see how much time is left for it to be done.
Yup - I usually open a new tab so that if I have to rerun something on the prior job (if something didn’t cut through) I haven’t moved anything and can just run that section again.
