Hello,
My left belt is tight but the right is sagging. Is there an adjustment?
Yes, you can make a simple adjustment…you’ll need a hex wrench.
Where would the adjustment nut be on the GF?
If you read the description at that link in the post before, it shows you pictures and tells you the steps to take.
Thanks!
Thanks for the answer @Jules! Those steps will help get your belt tension back to where it should be. Once the belt is adjusted, please check the tension. When pressing lightly on one side of the belt, the other side should not move.
Like this:
(You should see an animated image above)
Once that is done, try a print and let us know how it goes!
