Lost wifi when calibrating
I needed to calibrate my machine because we took it outside to clean it. I went through the steps but after it did the scoring I got a message that it wasn’t complete because it lost the wifi. I can cut all day and never loss wifi. So I tried again and received the same message. Is there something I can do to get the calibration to finish
Someone else on here had that issue - something to do with the sheer quantity of data that’s passing was too much for the connection. I believe their solution was to switch to a phone hotspot for just the calibration. I’ll see if I can find the thread talking about it - but it’s worth a shot.
Thank you so much. I will give it a try.
Hello @tandersen3886,
Thank you for reaching out to us. I’m sorry to hear your Glowforge is having connectivity trouble.
I took a look at the logs for your unit and it looks like your Glowforge is able to connect successfully to your network, but it may be having trouble maintaining a stable connection. When this is the case, you won’t need to go through Wi-Fi setup again, but you may see an “Offline” message.
  1. Turn off the computer, phone, or tablet that you’re using
  2. Turn off your Glowforge
  3. Unplug your modem
  4. Unplug your Wi-Fi access point
  5. Wait one minute, then plug everything back in and turn them back on
  1. Improve the signal path between your Glowforge and your Wi-Fi access point
    Wi-Fi signals need a clear path. Remove physical barriers, and move devices closer together:
  • Move your Wi-Fi access point up high and make sure it’s in an open space. Avoid locating your Wi-Fi access point on the ground, under a desk, in a cabinet, or in a corner where its signal can be blocked.
  • Relocate your Wi-Fi access point closer to your Glowforge
  • Move your Glowforge closer to your Wi-Fi access point
  • Install a Wi-Fi range extender closer to your Glowforge
  • Run an ethernet cable and install a second Wi-Fi access point next to your Glowforge
  1. Reduce electronic and Wi-Fi interference
I hope this helps. Please let us know how it goes. Thank you!
