Oh that’s a good result, well done. How long did you let the ink stay on before wiping?
sprayed and wiped immediately. It’s dye based, so I didn’t want it to stain anything else but the lines.
I used speedball water based ink once. It worked but wasn’t terribly color dense. The end result was a silvery grey that I like but was unintended.
I tried stamp ink once too, it was ok but against not as dense as you’re seeing here. I may have to get some of that spray stuff of yours.
That color is beautiful.
Nice!!!
If it helps at all, I did two passes on the Glowforge - Full power, 200 speed. The dye inks are called Dylusions Ink Spray by Ranger.
That is a beautiful owl!
Thanks for sharing that Dylusions works…I have some other spray inks, but haven’t tried any of them yet… Your owl is great! I am sure your daughter will be delighted!
