I mentioned Johnson Plastics earlier, but they just launched a new site featuring stuff from Laserbits and Inventables. So, yay more colours! http://www.johnsonplastics.com
I also recently heard a rumour about PVC-free adhesive vinyl so I can safely go back to lasering the vinyl directly off my glass for sandblasting. Now to see where I can get my hands on some! http://www.grafityp.com/gef-serieUK.html
Here’s a source for PVC free vinyl. I haven’t tried it with sand blasting or etching. Maybe the woven characteristics would cause a problem with edge bleed, not sure. If you’d like to PM me your address, I can send you small #10 envelope piece to play with before you consider an order. I’d never thought of lasering the vinyl directly on glass before blasting.
A bit of both. I usually call ahead. They have a lot of my materials on hand since I order the same stuff so often, but sometimes they have to bring it in from their other warehouses. What they do have is sample chips and a bunch of idea stuff, so if they don’t have it in their warehouse, you still know what you’re getting.
I just back from a ZeroLandfill event. Happened across them on Craigslist in the free section. They take samples from local businesses and give them away to artists and others so they don’t end up the landfill. This was the second weekend, so I’m assuming it was a bit picked over, but I was still able to pick up everything below. I’ll definitely have to do some checking to make sure everything I grabbed is laser friendly.
I would definitely recommend a wagon of some kind. I had no idea what to expect so I took reusable bags and kept having to empty them into my car. Also, for those who actually own tools, they did have quite a few larger sections of tile and stone, but I don’t have a way to cut them, which is why you only see small square pieces in my collection.
Nice score!! Maybe I should check around my area…we have lots of home builders stores…I’m sure they probably have outdated material samples
I can see these small pieces be perfect for mossaics or inlay work
I got yelled at recently for doing this when I was collecting metal strapping/banding for a project. When the guy actually slowed down enough to talk to me about what I was collecting though he was fine with it and even told me where there was more.
I also drive by a bunch of stone countertop supply places regularly and there is always busted up stuff in a pile. I keep meaning to stop and ask if I can have some, but perhaps I should wait until I know what to do with it…
Yeah right. Who am I kidding. Horde it, horde it all!
OK - This came just 2 days after THE announcement. Ouch! This supplier has been mentioned before, but this order was just over the $150 (not including shipping) ProofGrade value that we are set to receive. I’m hoping for a variety of acrylic in the GF package, but here is a sample of the amount of hardwood/plywood in that $$ range. All look very nice, sanded and smooth on both sides. Will have to add paper transfer tape to deter smoke damage, which will not be necessary with ProofGrade.
I picked some of the least expensive woods for the first practice runs. Hope I didn’t pay way too much, but it was very convenient to Click Shop. Probably too easy!
Has anyone thought of using laminate flooring for small projects? I was organizing some stuff in the basement and saw the excess pieces from some home projects. The seem to just be pressed fiberboard with a printed design. I know that at least one of the manufacturers of my material is Armstrong. They didn’t have any specific info about PVCs on the laminate. I have an e-mail into their FAQ page regarding this. I hope it is OK. It always seemed that I needed just a little more and have 1/2 to 3/4 cartons of the stuff stacked in the basement. The planks that I have are only 5 inches wide, but could make some quick little boxes with pre finished faces. Local flooring installers or shops would also be a great place to get some free scrap, either excess or old samples.
