Maximum material size
#1
Given that the current cutting size is less than the desired 12x20 inches, can someone tell me what is the absolute maximum material size that can be laid into the machine ?
Is it 12x20 or is it slightly larger, and if so, by how much ?
Assume thin card, rather than 1/2" timber !
#2
The “nominal” size would be 18" x 20".
If you’re looking for a fractional inch beyond that, each machine could be different based on assembly. You’d have to measure your own.
#3
Thanks Dan, I had no idea that the area was so big in the 12" direction.
Very good news.
#4
You can go up quite a bit in Y but I have never measured it.
