Can I cut mirrored acrylic or will that cause reflection?
Mirrored Acrylic?
ben1
#3
Per Glowforge, mirrored acrylic is non-reflective to the Glowforge laser beam and will cut just the same as normal acrylic.
brokendrum
#4
Acrylic seems to work fine. Some plastics even block UV light, but none I have used yet seemed to matter (other than extruded wanting to slag and melt, that is).
However, I tried some mirrored card stock once, and could hardly touch it. I finally turned it over and could cut from non-reflective back, but looked fairly burnt with char on edges when done.
wbgraphic
#7
You are correct.
Like other CO2 lasers, the Glowforge beam is in the infrared frequency (~10,600 nm).
