Looking for some input on why this is lacking detail… Sorry I’m fairly new to this Glowforge stuff. Its Mahogany wood and I did all of my measurements after removing the honeycomb tray. This was just a normal JPEG picture that was imported into the Glowforge app. I did full speed and 80 percent power. Lines per cm was 90 and I did four passes. Was hoping to have a little more detail along the “Ribbon portion” and the “Top crown” of the crest as circled. Any input would be greatly appreciated.
Oh and FYI, I used a scrap piece of wood which had a a little stain on it which is what you are seeing at the bottom of the crest.
I think they’re fine…you’re getting nice dark engraves. (You can always go up one setting on the Lines per CM if you want to try a deeper engrave, but that might char a bit, so maybe just a small test square to see how deep it goes.)
