What am i doing wrong that when i download free files from the community i just get a pic and not the cut file.
When you download a cut file with joint fittings like cuts to join the piece together is there any other way to change all the fitting cuts size to fit the thickness of the material other than changing each one individually.
Are you right clicking the file or the picture of the finished item? The file almost always resembles a line drawing which you “save image as” to your computer. As for changing joints, it may be possible to alter the entire file by the percentage change you are making for the material thickness.
