I want to modify the Medium Plywood Thanksgiving Holder to use thicker wood (.25"). I want to change to slots to accept that. I tried ungrouping but it still won’t let me change only the width.
Since you want to make holes bigger and not smaller, this can be easily done by adding the bigger holes over the smaller ones (going the other way is much harder).
Other than making the whole design bigger or smaller, you cannot modify a design from the catalog.
When widening slots, I make a “U” of the appropriate size, and in Inkscape at least, I can easily position copies centered on the original narrower slot…
As stated you can’t modify catalog design paths to make them smaller, but I think you can add the “U” and make as many copies as you need. If you are just working in the simple GF UI, you’ll have to align them by hand…
