Hi, I traced some artwork and saved it. Does anyone know how to import it into an existing design I have on my dashboard? Thanks!
If the saved artwork is on your computer, simply drag and drop it onto the interface with the other design open, or click the Plus button and select upload while the other design is open.
Thank you so much! I thought I could only use their images with that plus sign. Thank you again!
I was also trying to import artwork into an existing design. Thank you so much for the information concerning the plus sign. Where do you find this information? I wish someone would write a book on all the actions you can perform with your Glowforge. Thank you again
If you work through the First Prints tutorial you are off to a good start. Then, refer back to all the things in the tips section. https://support.glowforge.com/hc/en-us/sections/11792517736475-Learn-by-Doing
Thanks, I’ll do that
