I don’t have my GF Pro yet, but I already find myself in category 4. I had some core thoughts about what value I would get from the GF and then all of you amazing people on the fiorum opened my eyes to so much more. Now I anticipate that I will be frustrated by not having enough time to think them all through and create them. Someday, I will retire and then…
I don’t know if you’ve gotten your machine yet. But I’ll tell ya… The variance I’m getting is so good that I take my jobs to the (near)edge of the material and it nails it every time. I’m not saying it’s 0.00" or anything. Here in the real world, it’s not (yet). And I think some people get the wrong idea about what’s actually off. Everything you cut will be perfectly precise (kerf not withstanding). If you say you want to cut a 3.76" diameter circle, that’s what you get. It’s only the placement that can be off by up to 1/4". And that’s the largest margin of error the absolute farthest you get from center. I think, for many people, it’s rare to take, say, a 1" circle, decide to put it in the lower-left corner of the bed for some reason, and need to perfectly align a design onto it. Drop it in the center and Bob’s your uncle. Plus, if one really really really wants to hit that 1" circle in the lower-left corner, there are workarounds described throughout the forums that will get you exactly that.
Hope that long-winded speech helps you (or at least somebody)!
Same here - I didn’t buy it for any one particular thing, but because I continuously have ideas that I want to try, and some of them aren’t the kind of thing you make with a 3D printer! So while I’m sure we’ll be making things for cats to climb on / through / under , I spent the weekend laser-ing keychains for e-NABLE (a non-profit that gives away 3D printed hands for people missing fingers, etc, http://www.enablingthefuture.org ). The GF made that so easy, it took just minutes to pull up the keychain template, drop in their logo, and start printing keychains for people. And next week, who knows what weird idea will pop out.
And I have to say - lasering cardboard is AWESOME! Amazon provides an infinite supply, and you can try out ideas so quickly and easily…
There are a few of us eNABLErs here - you’ve got company
I got involved as much to find some real use for my 3D printer as anything else but it’s a great group. Lasers are great because you can find an infinite number of uses for it everywhere - I get far more utility out of the lasers and CNC than I do/did from the 3D printer (that doesn’t stop me from backing new ones on Kickstarter though )
That’s precisely the precision I need. Imagine a very expensive sheet of specialty paper with a hundred tiny high resolution labels on it. I need everyone of them to cut out perfectly. That is not possible with the current
On the contrary. It’d work perfectly. I must not be explaining myself well. I apologize.
You’re actually doing the opposite of what I was saying… You’re not working with a 1" circle. You’re working with an entire sheet. So it’d be pretty easy. You design your cuts. You lay your material. But you align to the center. Everything else is relative. If the center is on the mark, so will be the rest.
That said, when you say “tiny” can you give me some specificity there? If it’s as small as you make it seem, many will tell you to simply make a jig for it. It will work perfectly 100% of the time.
If you give me some idea of the size of these things I’ll be happy to run off something similar, if possible, so you can see it for yourself.
I’m going to be honest with you…I don’t think this is the machine you’ll want to use to cut out a sheet of hundreds of tiny labels. That’s a Print and Cut file, and this laser isn’t designed to work that way without a lot of fiddling. (There are a couple of tutorials on the workarounds in the Tips and Tricks Matrix.) Even with perfect visual alignment, there are going to be better tools for the job.
I’ve used both now, laser and digital cutter, and your best bet for the labels is a cheap digital cutter. I can highly recommend a Silhouette machine of any kind - it has a dynamite 3-point registration that will work at the tolerances you need.
If you need the laser for cutting out parts in wood and fabric, or want to engrave on them while it’s cutting them out - that part, it’s going to handle beautifully. But it isn’t designed to cut out accurately around a pre-printed object. It’s designed to engrave in relation to a cut that you tell it to make.
Hope that helps. I just don’t want to see anybody buy this thing without realizing what they’re getting.
Thank you for the honest reply. That is not the only thing I wanted to do with the GF but it is one of the things that would not be possible with the current problems.
I ordered it for x and it does x well, and it probably does y and z well too, but I’m here because I’m either lonely or procrastinating. Or why not both? I can pretend this productive use of time. It’s practically research…
Oh, just me?
Seriously, though, I’ll also probably be here for a lot of “I pushed the thing and it didnt do the other thing, so then I unplugged it and plugged it back in, and now it’s on fire.”
I read from the bottom up and thought youd made a giant penny on the glowforge. Lol. I was like “uh, bananas for scale. Not bottles of soap.”
So… Well done! Thats amazing. I recycle paper scraps smaller than 6x6 because theyre too fiddly, but you make things that even a mouse would think is small.
I didn’t make the tiny dish soap. A friend of mine makes those. She cuts every tiny label by hand. It’s very time-consuming. I offered to cut them out for her once I get my GF.
Thats what I get for reading in reverse I cant imagine cutting those out by hand and not going crazy. I hope they get the glowforge working so you can do stuff like that. I hate that the placement is so inaccurate. Its too inaccurate for the stiff I want to do, too.
