Need objects in a line?
Hi everyone,
I am working on a project inside the glowforge interfacing. I have many small circles and I need them to all be in a straight line (in a row), but this is difficult to do with a mouse. Is there a way to group copy the many circles and then align them in a row or straight line? I hope this makes sense.
Select each one of them and then use the alignment/distribution tool. It is the icon next to the measurement tool. You can also check the center x,y position of one of the circles and use the same center coordinate for all the others.
Got it ! Thank you so much.
One more question. Is there a way to make the circles that are now in a row to align in a semi-circle or half moon shape?
Not to my knowledge in the Glowforge interface. Possibly in an outside design program.
ok Thank you :slightly_smiling_face:
That’s a pretty trivial operation in Inkscape.
ok I dont have inkscape, so I guess I need to download it today
You could draw a circle in the interface and manually place the smaller circles as you wish, and then delete the large circle.
Yes, that would work ! I will try that first, thank you !
Inkscape (for vectors) and Gimp (for rasters) are pretty standard free software with lots of users here. There are plenty of other programs out there to do the same thing (many fairly expensive) but there is a learning curve with all of them.
This is working great ! Thank you
Another possibility if you have Glowforge Premium is to use the new Pattern Line tool:
