You might want to post this in âbeyond the manualâ or another section, as the glowforge staff probably wonât assist with not-proofgrade materials.
But to answer your question, have you tried doing two cuts? Where you input the speed and power settings there is an option for âpassesâ. It automatically sets to 1, but you can change it to 2 or 3, I believe. Which just means it will cut the design once and then immediately cut it again in the exact same spot. You might be able to cut through more easily by doing two passes at a quicker speed than one pass at a slower speed.
Have you done a good cleaning? To all of the windows, lens etc.?
Not all BB is made the same but that still sounds slower than it oughta be. I have a pro so my settings will be different⌠but I can use 125-130/Full Power/.208â focal point (the 125 is kinda slow but more consistent).
Itâs probably not super appealing, but the results you really want might be the plus or pro model. Theyâre 20% ⌠faster, I think? Or maybe it was more efficient. Not sure. But the laser tube is a higher wattage, which means more potential power. Their full power is stronger and more cut-y than the basic full power. If you plan to regularly cut 1/4 BB ply, maybe selling and upgrading would be worth the time and additional cost.
Thanks for reaching out. Unfortunately, like @erin mentioned, I donât have any advice about settings for materials from other sources.
If you are considering printing on materials from another source, youâll need to determine if the material is laser compatible. This can be tricky: for example, many plastics look alike, and some plywood is made with glue that isnât laser-compatible. You need to contact the manufacturer, inspect their safety data sheet (SDS), and/or consult an expert to determine if each material is compatible with the CO2 laser inside the Glowforge unit.
Since youâve already created a new topic in the âBeyond the Manualâ section of the community, Iâm going to close this topic. Please post a new one if you have any other questions!
