SO excited to see the new feature about copying from one design into another in the GF workspace; which I have wanted for awhile.
However, it’s just not working.
I am using an Apple MacBook. I have a Premium Subscription. I have used command/copy on keyboard. However, when I go into the new design, nothing happens.
If you are in one design and have another window open, you should be able to paste to that second window. If you close out of the window the data in the copy is lost.
Unfortunately, I have tried all 3 web browsers; AND opening separate windows in various formations, and it STILL doesn’t work. I have. tried premium art/text, my own art/text.
I am at a loss.
Just to go over this one more time, you are selecting an object, clicking command c, then going to a different design and clicking command v and nothing happens?
Can you copy and past within a design with these keys?
I am unable to copy and paste as well. Same scenario. Safari and Bing. Using ctrl-c then ctrl-v. Also used the UI copy and paste. Was this a recent update?
I just now used it. I opened both windows, used the popup to copy, then went to the other window and used the popup to paste,
It worked perfectly!(except the part would not fit in the cutting area)
Send Support an email. They don’t monitor the forum, and since the process works for many (most) users, they will have to work with you to get your interface working properly.
