Hi - I got the new Pro on Thursday and set it up to cut which it has done nicely. Today after a cut I have the yellow light indicating too cold. This was after using it for about an hour. I have a small space heater in the shop and the temp inside the machine says 79 degrees on the thermometer. Is there something I am missing?
Unless they’ve changed something (and they do, and sometimes I don’t keep up) a blue light indicates too cold, and an orange light indicates too hot. Are you getting any messages on the screen saying there’s a temperature issue? You have a Pro, so it can handle 79ºF, but what if your thermometer isn’t perfect? Or what if the laser cutter’s thermometer isn’t perfect? I’d suggest you get the internal temperature of the unit down a degree or 2 and then restart it and see what happens.
The temp was in the low 60s in the shop and I warmed it up to mid 70s to get it warmer. It must be something wrong with a sensor etc as I hit the entire range and still the same light. Yellow light means something wrong with a sensor?
The temp that matters is the fluid in the cooling system, which will take longer to reach the ambient room temperature. I’m not sure how long it’s been, but it could be you just need to wait a little longer.
The yellow light is just a temperature warning. A faulty sensor could cause it to erroneously report the temperature being out of range, but it doesn’t necessarily mean that’s what’s wrong.
Figured it out. I looked at the cable connecting to the tank in the front left and black wire was just hanging out of the white clip. Touched it to the clip and yellow light went away. I was able to take it out and get it back together but will need to be replaced! Yea, back to cutting!
I’m glad you resolved it! I can see that you’ve also reached out via email and that our support team has contacted you there. To avoid duplicate communication and expedite your process, I’m going to go ahead and close this topic. I have responded to your email ticket about this issue,
