I don’t know if this has to do with using the pass-through slot. This is my first time using both sides of the pass-through. When I loaded the PG draft board and graphic, I tried to hit print and it showed “no artwork” (you can see in the picture. I’ve used this file before, I’ve done cut and score with it before…I just don’t see anything clearly that I’m doing wrong. Please help!
Looks like your artwork is gray. That means it is outside the print area.
What it means to say is that “there is no artwork I can print”.
Okay! Thank you for translating. I’m new here! I appreciate your help!
