No Artwork message on Glowforge
Getting message “No Artwork” I have cleaned the machine.
If any part of your image is outside of the cuttable area then it will all be ignored. And if that is all you are showing you will get the “no artwork” message as there is nothing it can cut/engrave. If you put the engrave on ignore, it may cut the object but it will not be able to engrave at that location.
Thanks for your response. - I eventually worked out what the problem was!
Glowforge really ought to replace that message with something more informative. It confuses everyone!
you get it going yet?
