says no artwork but I can see it on the screen. I’m using the pass through for the first time and this is where I am having the problem
Welcome to the community!
Is your artwork within the grey bars - and showing up coloured (pink when they’re not actively selected)? The bars move depending on what settings you’ve chosen (same as with regular printing).
gray bars not turning red even after I move it around
I’m using the same files I would use on a project that would fit 19x11 board but this word is larger than that so I figured I could use the pass through to do this
sorry Dierdrebeth everything is in the printing area but the artwork is gray and I have selected the cut I wanted and auto focus on the board but the artwork will not turn red to accept the work
Can you share a screenshot of the bed and the interface?
PROBLEM SOLVED THANKS EVERYONE I am
very new to this machine and I just learned that you have to have your artwork all the way to the top sorry for the trouble.
Just to clarify, your artwork can be anywhere AS LONG as it doesn’t extend into the grayed out areas. That’s when it will say no artwork…
Yes I figured where I went wrong since it was my first attempt at the pass through
Thanks for your help
