For a long time now I have been using hand sanitizer to clean almost everything, mostly wood but I have left Acrylic in sanitizer for weeks with no issues except that all the masking fell off and floated away. There was no damage to the acrylic.
Just now I tried to do so again and the masking fell right off however the acrylic was severely damaged. As the need has increased I increased the size of the bottle from half-pint to gallons, but the formula is obviously different in the volume quantities.
Good to know. (Of course no one has any hand sanitizer available these days, but that will change one day.)
I probably have a couple liters left in total but apparently can’t use it on acrylic.
If it eats through acrylic I’m not sure I’d want to use it on my hands either!
It also depends on the acrylic. I did a test recently comparing extruded with cast acrylic and the extruded was much more sensitive to alcohol and acetone.
I am pretty sure it was cast that I tried.
Guarantee that you can sell it for the original cost right now.
