I’m having a really weird challenge cutting basic white copy paper. If I look through the lid while it’s cutting, I can see the outline of what it’s supposed to be cutting. But it’s not actually cutting through the paper.
I’ve tried a variety of manual settings and the proofgrade 20lb copy paper (what I’m using) setting. Same results.
Everything else is cutting fine. Any ideas what’s happening?
The Proofgrade settings are 100/10. Can you double check that that is the power/speed setting you are using? Share a photo of your design on the interface and the result after usiing those settings.
I believe that one of the tutorials for the first prints for the Aura and the Spark was the Glowforge Gift box printed on 20# typing paper, so it is quite reasonable for a user to expect the craft machines to cut white typing paper. My Spark certainly does.
I don’t think you do. Not all white surfaces are created equally. It is definitely possible that OP’s paper is highly reflective of the specific wavelength of the Aura laser. If that’s what’s happening here then @eflyguy is exactly correct.
Nobody [1] has a spectroscope or spectrometer at home, so the fastest thing is to just try a different type of paper and deduce. The evidence supports @eflyguy.
Almost nobody. I don’t but if someone wanted to give me one I’d love it ↩︎
