I have wasted so much money on Proofgrade material. My cuts continue not to cut completely through the material. It is on proofgrade material, on proofgrade settings. I have refocused the machine and have cleaned it. it works 50% of the time. Please help as I cannot continue to waste the hundreds of dollars I have already lost
When you purchase Proofgrade part of the cost is a warranty that it âjust worksâ if youâre using PG settings. This is why itâs good to read the information they send you!
That being said âit doesnât workâ isnât actually helpful information. What are you cutting? When did you cut that it didnât work? Give details, and preferably a picture of the Gift of Good Measure (from your dashboard) cut, both front and back, with the time you did it.
I am having the same issues. I just printed an item on Proofgrade MDF with Proofgrade settings, and it did not cut the item all the way through. Itâs like it scored it instead (yes, I double checked my setting for cut!). This has happened on not just MDF, but with PG Basswood also. Itâs frustrating to do a large piece and find out it didnât cut all the way through!
Iâm so sorry to hear that your prints arenât cutting through on PG material.
Could you please post two photos of the front and back of an example print so that I may take a closer look?
Please also let us know the date and time of the print (including time zone) in your reply.
There are several things that need to be checked if the laser doesnât cleanly cut through the material. Weâve discovered that photos donât always come through well in emails, so Iâve included several links that will take you to reference instructions and photos. Please turn off your Glowforge and check the following:
- The crumb tray is clean and properly installed
- The material is perfectly flat on the crumb tray
- All optical components are clean and undamaged
- Design is set to âCutâ
Once all these things have been checked, please perform the following test print. By the way, Iâve sent you a gift card to your email so that you may purchase more Proofgrade materials if necessary. I apologize that youâve wasted materials in this process and want to help you resolve this for good!
Print the Gift of Good Measure on Proofgrade material, using Proofgrade settings.
When the print finishes, leave the lid closed and wait until the fans stop and the picture updates.
Check the completed print:
- If the Gift of Good Measure fails to cut through, take a photo of the front and back of the print, and attach these photos to your reply.
- If the Gift of Good Measure cuts successfully, please try another print of the design you experienced the issue with, and let us know the results.
I look forward to reviewing your results!
Mine does this as well. I had to do 3 passes on PG thick acrylic last night and there were still a few spots it didnât cut all the way throughâŚ
Each thread can only help one person. If you havenât already opened a thread of your own, or emailed support, you should do one of those things.
The GoGM is in your dashboard.
