Laser is not printing or cutting in the correct place?
It had been OK now most things are staggered
What kind of laser? This is typically an issue with belt tension or debris on the rails. The craft lasers are very much more prone to this, requiring constant cleaning.
Welcome to the forum.
Which laser do you have and can you share a photo/screenshot illustrating the problem you are having? Did this new behavior start after some event - like you just cleaned it and now this problem has arisen?
I had this happen last week after I did a deep clean of the Pro….realized I forgot to adjust the tension of the belt after replacing the printer head. Once I did this, I am back up and running as good as ever.
I never adjusted the tension on my belt(s) in all the years I owned my first machine.
Thanks for info
It is the Glowforge Aura
I forgot to say it makes sense as majority of work is engraving/cutting on 1.6mm acrylic (plaques for a pet crematorium )
