djfb
November 16, 2020, 1:11am
So using safari on an iPad I have found a couple of things I don’t know how to overcome them.
Using the GF Interface, I created 3 different rectangles. How do I get the dialog box, when one is selected to hide?
If not, is there a way to move it? It takes up an awful lot of space on the inter face.
Same for the corners/points dialog box.
How do you make a copy/paste of an object I created with the forms dialog box?
Also how do I delete an item? Accidentally put a leaf image on it when exploring.
djfb
November 16, 2020, 3:24am
Not the measurement box. That one I know. I’m talking about the ones to the right of the window
And how do you delete something I.e. the leaf
You can’t. But you can set it to “IGNORE” and drag it to the bottom of the list so it’s not really in the way. I do this a lot. Separate my print in to a lot of layers so I can set things to IGNORE if I’m not cutting the entire project (like if I break a piece and need to cut it again, but don’t need all the other pieces).
randy.cohen:
You can’t.
You can. Click on it and it and delete it - unless the iPad literally doesn’t have any sort of delete or backspace button?
djfb
November 16, 2020, 4:54am
6
It doesn’t, and in addition, the copy/paste doesn’t work in the interface on the iPad either. At least I haven’t been able to make it work…
ekla
November 16, 2020, 10:10am
7
Copy/paste and delete only work on iPad with a Bluetooth keyboard attached.
djfb
November 16, 2020, 4:11pm
8
That makes sense. And I used to work in the apple stores for 9 years. SMH
KelseyM
November 18, 2020, 12:23am
9
Thank you all for the tips, that’s right. I’m going to close this thread - if you have further questions, go ahead and post a new topic.
