Mine never has, but maybe if you put a few QR codes in different places maybe it will…
Never? That’s unusual…I’ll get one that misreads once in a blue moon, but the sticker is usually smudgy or something.
Eventually, the plan was to do away with the stickers entirely and do a preprinted masking with UV light codes printed all over it. Don’t know if that’s still the plan, but it would be a cool trick.
I suspect they stick the stickers as far out to one corner as they can because they do interfere slightly with engraving depths, and anybody wanting to do a large full sheet engrave would have to take it off or wind up with a sticker shaped light spot on the finished product. It eats into the useable area on the material a bit.
mine never read the PG codes either. I asked support and they suggested making sure the bed was seated well in dimples and that the bed was level. I finally just said “whatever”, and pressed on.
Yup, never. I only can run the at night and have no lights around it. But since I know what it is I just change the settings.
Not complaining because its wonderous! (Glowious)
I extracted the logs to investigate the problem you reported, and the first thing I’d like you to try is to give your camera a thorough cleaning.
Please check out our cleaning and service guide.
If you finish that and your Proofgrade material is still not being recognized, please let us know.
I did try cleaning the camera with the provided wipe, but they were dry. I have ordered a new box and will try again. But it has never recognized the QR code. From day one.
Will update once I get the new wipes.
