Don’t really know what to describe because really not much is happening… switch it on… makes a whir sound… usually then theres a ticking but nothing… leave it it and then 15 minutes later the laser head moves a little
Booted it many times
Reset the wifi and connected no problem
Nothing else I can tell you apart from it was working fine and then I tried to do one last print and it stuck on preparing to print for 10-15 minutes… that was first sign of problem
Looks like it’s an issue across the board, they are working on a fix now… I got pissed because mine was working fine this morning and then nothing, but they will get it fixed (hopefully quickly)
I’m sorry you ran into trouble. We were experiencing a system outage at the time of your report and I believe this caused the issues you were seeing. We’ve resolved the cause of the outage and you should be good to go now. If you’re using the App, you may need to refresh your browser.
