Hi all… Has anybody else had an issue with high speed rail skew? It’s happened twice in the three months I’ve owned the Pro. Both times it’s happened with the material targeted bottom right of the bed when I’ve been doing multiple prints. It then flies to the bottom right hand corner from it’s start position at supersonic speed?
Does this happen after you have used the set focus tool? I have not experienced this in the many years I have had my Glowforge.
I don’t touch the set focus. It’s on auto and my material depth is entered
That sounds like one of the belts might be a bit loose, presuming there is not something blocking the passage. the fast start is normal.
