My glowforge is offline and is not even centering. I’ve never had this problem before and i have had my machine since September 2020
Sometimes something causes a new interference. It could even be something nearby on a neighbor’s network. If you have tried resetting your modem and router and it still won’t work, try moving the router a bit or re-set up the wifi. To confirm that it is a wifi issue, you can try using your phone as a hotspot and bypass your home wifi.
Do you get clicking from the print head when you power it up? If so, try turning it off and move the laser arm to the center of the bed and then turn it on.
