Good day.
I was firing off the forest section from the Catan pdf. The score and cut outs and quite off from the engraved area. I feel like these might be known issues at this point, but just filing a ticket.
1/8" Baltic plywood(not pg) painted with acrylic paint. Green masking on both sides.
The imported file was the pdf into inkscape, then saved as SVG. The only odd thing I may have done was rotate the image slightly in the GFUI to get it on the work piece.
For the log, look around 12 pm EST , January 7th.
Also as always, the whole thing was off from positioning of the camera. Only reason that surprised me was that it was pretty centred on the bed.
Thank you.
